Edit problem of a module
Hi everyone,
I want to modify the code of the  "module axi_ad9371_rx_jesd_imp_GUTUBY" I when i going to edit i can not do that. I saw some instruction in the right corner that "Read-only". So can you please how to edit the code of this module?
regards,
Amitava
Re: Edit problem of a module
Hi middyaamitava@gmail.com
Please refer to this forum.
Cheers
Cheers
