Newbie mt@cu18
Error: [common 17-165] Too many position options when parsing '-force'....
Hi All,
When I create and package of IP, an error messages of [common 17-165] is found.
And I am refer lot of information and regarding on the relative error is due to spacing in the path.
But after double check and find there haven't any spacing in the path and I have try different name in the block. but the same error is found. And who are know what is the problem is?
Best Regards
Re: Error: [common 17-165] Too many position options when parsing '-force'....
It is hard to say what the exact issue is with the information given.
The error is stating that a Tcl command has more arguments than expected for a given command or switch within the command structure.
The most common accidental cause of this that I know of is the inclusion of a backslash character without being properly escaped.
See "https://www.xilinx.com/support/answers/46668.html" for more details on that.
What is the command that you are running?
