Madhuri_C_N
Error opening composite file
Hi, we have installed Vivado 2019.1 version in linux OS. When we try to create HDL wrapper from block design, we are getting error as follows
"filesystem::recursive_directory_iterator directory error: Transport endpoint is not connected".
Can anyone suggest how to overcome this error?
Thanks in advance.
amaccre
Hi @Madhuri_C_N ,
Are you launching Vivado from your ~/tmp directory instead of the project directory? Launching from ~/tmp has been seen to cause this issue.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
