Error "array index out of the range"
When i try to do "open elaborated design"  it gives me this error. (error in the multiplication section.)
Thank you.
    subtype mask5 is integer range -16 to 15;
    type mask_type is array(integer range <>) of mask5;
    subtype mask_9 is mask_type(0 to 8);
constant mask : mask_9 := (-1, -1, -1, -1, 8, -1, -1, -1, -1);
signal p1,p2,p3,p4,p5,p6,p7,p8,p9 : std_logic_vector(8 downto 0);
    p1<='0' & window(71 downto 64);
    p2<='0' & window(63 downto 56);
    p3<='0' & window(55 downto 48);
    p4<='0' & window(47 downto 40);
    p5<='0' & window(39 downto 32);
    p6<='0' & window(31 downto 24);
    p7<='0' & window(23 downto 16);
    p8<='0' & window(15 downto 8);
    p9<='0' & window(7 downto 0);
  variable sum : integer:= 0;
                sum := 0;
                sum := (  to_integer( unsigned(p1)) * mask(1)+
                          to_integer( unsigned(p2)) * mask(2)+
                          to_integer( unsigned(p3)) * mask(3)+
                          to_integer( unsigned(p4)) * mask(4)+
                          to_integer( unsigned(p5)) * mask(5)+
                          to_integer( unsigned(p6)) * mask(6)+
                          to_integer( unsigned(p7)) * mask(7)+
                          to_integer( unsigned(p8)) * mask(8)+
                          to_integer( unsigned(p9)) * mask(9));
You need to reference mask() starting from index 0 to fix this error:
                sum := (  to_integer( unsigned(p1)) * mask(0)+
                          to_integer( unsigned(p2)) * mask(1)+
                          to_integer( unsigned(p3)) * mask(2)+
                          to_integer( unsigned(p4)) * mask(3)+
                          to_integer( unsigned(p5)) * mask(4)+
                          to_integer( unsigned(p6)) * mask(5)+
                          to_integer( unsigned(p7)) * mask(6)+
                          to_integer( unsigned(p8)) * mask(7)+
                          to_integer( unsigned(p9)) * mask(8));
