Error "port is not recognized"
I'm trying to add module to the schematic I designed, but I got an error because of types.vhdl.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
package types is
subtype pixel8 is std_logic_vector(7 downto 0);
type frame_type is array(natural range <>) of pixel8
subtype frame9 is frame_type(0 to 8);
end types;
what can I do?
Hi @fpgatr ,
>> "user defined" type which i defined, will runs on the card without any problems?
What do you mean by "will runs on the card" ? Please elaborate.
This limitation is for IP packaging only that top level ports are std_logic or std_logic_vector if you are using VHDL.
hemangd
frame 9  defined in  the types library.
this is also complie order
Hi @fpgatr ,
User defined type is not supported for top level ports .
As per UG 1118, - To ensure that the custom IP simulates properly when using VHDL, set the top-level ports to be std_logic or std_logic_vector.
Check for more info. on it, page 11, Top-level HDL requirements . https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1118-vivado-creating-packaging-custom-ip.pdf
hemangd
I did the "port mapping" manually. then I synthesized and gave no error.
Does this mean that the "user defined" type , which i defined, will runs on the card without any problems?
Hi @fpgatr ,
hemangd
