k@ppa
Error when opening checkpoint
Hi all,
I have downloaded some benchmarks from http://www.ispd.cc/contests/17/downloads/2016/ and I want to do some place & route on them.
The files contain a .dcp but when I try to open it with open_checkpoint I get this error message:
ERROR: [Designutils 20-1451] File header does not indicate /xxxx/.Xil/Vivado-100370-xxx/dcp5/design60_1_inst1.incr is an incremental info file. File was not read. Please verify the file is correct.
ERROR: [Common 17-70] Application Exception: Restore timing info for incremental flow failed due to earlier errors.
I don't know it goes to directory .Xil to say this is an incremental file.
Thank you in advance
Sincerely
howardp
These  DCP files are for a ISPD 2016 program and have been intentionally disable for opening in a standard Vivado setup.  They are only intended to be opened by participants in the ISPD 2016 program.
k@ppa
Anyone has an idea?
I tried creating a project and use read_checkpoint -incremental but it sends back the same message.
howardp
