Example design for 7 Series PCIe endpoint and DMA
Accepted Solution Solved
Accepted Solution
Is there an example somewhere in Vivado 2017.3 showing a complete design using the DMA/Bridge Subsystem for PCI Express (PCIe) IP?
If not, then is there a compete example that shows use of the DMA/Bridge Subsystem for PCI Express (PCIe) IP? I have read that there is a PIO example somewhere that uses this IP, but I have not been able to find it.
I am trying to understand using these IP blocks, and I would like to get started by building a complete known-good design so that I can see how the pieces fit together. I do not need, or particularly want, to be able to run the design. I just want to implement it into a chip so that I can see how things fit together.
Ian Lewis
www.mstarlabs.com
Re: Example design for 7 Series PCIe endpoint and DMA
hi @ilewis,
you can find the PIO interface in the example design. you will get the VHDL files in example design if your target language is VHDL.
please check the attached images.
regards,
reshma
All Replies
I found that there is a right click option on the IP, once you instantiate it in a project, that is called "Open IP Example Design".
That sounds at least somewhat promising, but it creates a Verilog example.
I would like to find a VHDL example if there is one.
Ian Lewis
www.mstarlabs.com
hi @ilewis,
please check these,
https://www.xilinx.com/support/documentation/application_notes/xapp1171-pcie-central-dma-subsystem.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp1286-pcie-axi4-lite-bridge.pdf
regards,
reshma
Please mark a response "Accept as solution" if a post has the solution to your issue. If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
hi @ilewis,
regards,
reshma
Thank you for your help, Reshma.
