Newbie abo_abed
FIR_Compiler_v7.2
I'm working in a real-time project, I want to use FIR filter formy analog input, the thing is that the FIR filter takes 16-bits data in and gives 32-bits out, but I want the filter to give an analog out to the ADC board I have. Is there a way for an FIR filter to take a single channel analog input and filter it out without the digital conversion? also what if I want to do the conversion first ? would it work ? and how would I deal with microBlaze to let it take the input and pass it through the FIR filter and then display the output?
Thanks in advance
Note: the ADC board I have is PmodAD1 from Digilent.
Scholar dgisselq
Re: FIR_Compiler_v7.2
@abo_abed,
An ADC board will take an analog input and provide you with a digital output.
FPGAs do not operate on analog signals, they operate on digital signals.  The FIR filter needs a digital input therefore.  You can provide this from the ADC board with a little bit of work.
The result will be digital.  Depending upon your design needs, that may either be good enough or you may need to convert to analog via a DAC of some type.
Dan
Newbie abo_abed
@dgisselq
Thanks a lot for ur help, I understand now mostly what I'm going to do. However, I'm struggling with taking the information of the time of the signal, so suppose I used the internal DAC of the FPGA to take the analog signal after filtering would I be able to process that signal on the FPGA  ? And for the ADC what do u mean by little work ?
Thanks a lot for ur help by the way I really appreciate it
Scholar dgisselq
@abo_abed,
What do you need done with the "time of the signal"?  That can take a lot more work, as few digital signal processing solutions properly handle the absolute "time of the signal" since it's normally irrelevant..
As for the ADC, you can see here what I needed to do to get access to the output of Digilent's Pmod MIC3.  That's what I mean by a "little work".
Dan
Newbie abo_abed
@dgisselq
thanks for ur effort mate.
I mean by time of signal (the time at which the signal entered the ADC board) so I can use it to determine some of the parameters in my project.
suppose I have taken the sample by the use of Microblaze and SDK so how can I relate the output of the ADC to the input of the filter and take the signal filtered ?
I know I asked a lot but u know I'm new to this field so please bear with me >>
