ahmed_alfadhel
FIR coe file
Hi ,
I am trying to use coffeceint values of FDA tool in my FIR IP core.
I started with a simple exapmle as below:
radix = 10;
coefdata = 0.08659436542927, 0.00579513928555, -0.06734424313287, -0.04031582111240;
But , when I treid to import the file an error is appeared, which is syaing :
"Invalid COE File-Cannot find radix with name: radix or memory initialization radix"
Pls, could you help to solve this error?
Kindly find the attached pictures.
rshekhaw
Hi @ahmed_alfadhel ,
Try taking out the spaces around the equals sign.
Also please check this link for syntax:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/cgn_r_coe_file_syntax.htm
Raj
rshekhaw
Raj
