Failed executing Tcl generator
When I wanted to generate DCM IP core, I got error.
I tried 32-bit and 64-bit tool and got the same error.
Does anyone can help me?
Thank you.
Welcome to Xilinx CORE Generator.
Help system initialized.
The IP Catalog has been reloaded.
Wrote CGP file for project 'coregen2'.
Customize and Generate
INFO:sim:172 - Generating IP...
Applying current project options...
Finished applying current project options.
Resolving generics for 'clk_wiz_v3_5'...
Applying external generics to 'clk_wiz_v3_5'...
WARNING:coreutil - Failed to generate file: core_v
    invoked from within
"deliverEJava $componentName GenerationOptions $TopLevel"
    (procedure "components::clk_wiz_v3_5::generate" line 36)
    invoked from within
"components::${componentName}::generate"
    (procedure "::xilinx::sim::generation::generateCore3rdParty" line 125)
    invoked from within
"::xilinx::sim::generation::generateCore3rdParty $parameters(componentInstanceID)"
    (procedure "main" line 25)
    invoked from within
"main $argc $argv"
    invoked from within
"return [main $argc $argv]"
    (file "C:\Xilinx\14.1\ISE_DS\ISE\coregen\ip\xilinx\primary\com\xilinx\ip\clk_wiz_v3_5\generate\run_legacy_tcl_flow.tcl" line 47)
ERROR:sim - Unable to evaluate Tcl file:
ERROR:sim - Failed executing Tcl generator.
Check if suggestions in below thread helps
http://forums.xilinx.com/t5/Design-Tools-Others/Unable-to-Generate-the-Cores-unprecedented-error/td-p/256014
Satish
Hi Satish,
I tried them but the problem is still there.
I searched on google and there are not many solutions to this problem...
Can you share the run_legacy_tcl_flow.tcl file here?
Vinay
