Failed to reload user IP repository
HI! I need your help.....
When Im trying to create an IP out of my project I get this message:
 [IP_Flow 19-1681] Failed to reload user IP repository '/raid/data/ISP2/users/lital/work_fa/blocks/ip_FA_v00/fpga/vivado_ip/card_dut_rev7_new2/card_dut_rev7_new2.srcs'. ''/raid/data/ISP2/users/lital/work_fa/blocks/ip_FA_v00/fpga/vivado_ip/card_dut_rev7_new2/card_dut_rev7_new2.srcs' is not valid: Path is contained within another repository.'
Ive been this a lot of times but in the last time I tried to do it, vivado crushed and from that point I get this message and dont know what to do...
can you help? thanks!
Re: Failed to reload user IP repository
Hi dima.mamut@samsung.com
Can you remove the first red color one from the repositories and retry?
As you already have card_dut_rev7_new2 (last one in the snapshot) folder added the first one which is sub-directory of this is not needed.
Deepika.
Deepika.
Hello dima.mamut@samsung.com,
Can you share the complete details on the steps followed to create an IP?
I suggest you to go through the following tutorial on Creating and Packaging Custom IP:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug1119-vivado-creating-packaging-ip-tutorial.pdf
--Syed
Are you packaging project using vivado IP packager?
Do you have any other user packaged IP in this project? Can you show us the snapshot of project settings --> IP --> Repository manager? Do you have any repositories added here?
Deepika.
Deepika.
Hi Deepika,
Yes, Im packaging project using vivado IP packager.
Yes ,I have other user packaged IP in this project.
I attached the snapshot - Thank you!
Deepika.
Deepika.
I can see my mistake!!! using twice the same repository...
thank you!
Please close this thread.
--Syed
