File print javascript error
I'm running Vivado 2019.1 on Windows 64 Bit. Just trying to learn the program and new to FPGA's. Also, using Diligent Basys3 Board.
I am able to install several of the verilog demo programs from the web on the board and they run correctly. The problem comes when I try to print the verilog source file from project manager using the file/print function. At that time the program throws the java exception errror listed below. I installed the lastest version of java with the same results. For now I'm saving the source file to disk and printing it with Notepad
I am trying to avoid reinstalling Vivado as it takes a long time. Any ideas to try?
Jim
# Xilinx Vivado v2019.1 (64-bit)
# SW Build: 2552052 on Fri May 24 14:49:42 MDT 2019
# IP Build: 2548770 on Fri May 24 18:01:18 MDT 2019
# Current time: Mon Sep 02 16:41:55 EDT 2019
# Process ID (PID): 4032
# User: Jim
# OS: Windows 7
# This report is an indication that an internal application error occurred.
# This information is useful for debugging. Please open a case with Xilinx.
# Technical Support with this file and a testcase attached.
java.lang.NullPointerException
at java.desktop/sun.print.RasterPrinterJob.setAttributes(Unknown Source)
at java.desktop/sun.awt.windows.WPrinterJob.setAttributes(Unknown Source)
at java.desktop/sun.print.RasterPrinterJob.printDialog(Unknown Source)
at ui.views.c.aE.run(SourceFile:59)
at ui.frmwork.a.dWF(SourceFile:132)
at ui.frmwork.V.dYl(SourceFile:67)
at ui.aX.actionPerformed(SourceFile:677)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/java.awt.Component.processMouseEvent(Unknown Source)
at java.desktop/javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.desktop/java.awt.Component.processEvent(Unknown Source)
at java.desktop/java.awt.Container.processEvent(Unknown Source)
at java.desktop/java.awt.Component.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Container.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Component.dispatchEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.desktop/java.awt.Window.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.desktop/java.awt.EventQueue$4.run(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
at ui.frmwork.b.d.dispatchEvent(SourceFile:88)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
Community Manager
Community Manager
Re: File print javascript error
Hi @techy5025 ,
This can occur if the current project directories do not have full write permissions. Are the example and current projects directories include the same permissions?
Thank you,
Devin
Community Manager
Community Manager
Hi @techy5025 ,
Thank you,
Devin
