FileStructure::encrypt1735: Nothing to encrypt.
Vivado% source G:/CSM/xilinx/project/ip_encryption/ipen_cmd.tcl
# set key G:/CSM/xilinx/project/ip_encryption/keyfile.v
# set rtlfiles G:/CSM/xilinx/project/ip_encryption/Add_IP.v
# encrypt -lang verilog -key $key $rtlfiles
ERROR: [Vivado 12-3330] encrypt 1735: Failed to encrypt ''.C:\Users\Admin\AppData\Local\Temp\temp4bd52ac1-ea0c-47e8-8d95-02ccd0278709\keyfile.v: FileStructure::encrypt1735: Nothing to encrypt.
The related files are attached.
I do not know if the keyfile is right. How to get the keyfile?
Re: FileStructure::encrypt1735: Nothing to encrypt.
Hi @xxwang
Can you try modifying the value of the set commands as follows
Before : set key G:/CSM/xilinx/project/ip_encryption/keyfile.v After : set key G:\CSM\xilinx\project\ip_encryption\keyfile.v
Before :set rtlfiles G:/CSM/xilinx/project/ip_encryption/Add_IP.v After :set rtlfilesG:\CSM\xilinx\project\ip_encryption\Add_IP.v
The issue might be because of the hierarchy file path separator i.e. windows is seeing the value of set variable as name of a file and searchind it in CWD instead of going to the directory and searching for the file.
Please try this and let us know.
--Suraj
