helmutforren
First Base with MIG on KC705 dev kit
I will soon have a KC705 dev kit.  I want to end up with my own project and code accessing the DDR3 memory.  I can't find the starting point.  I tried taking an existing project for the same FPGA, and adding MIG.  But I have too many unanswered questions.
I downloaded a bunch of KC705 stuff from Xilinx, and I have an xdc file, but I do NOT appear to have an example project.  I also can't find doc for how to get my first test case running on the KC705.  The "Getting Started" pdf is about Video Demo and BIST test that seem to already be programmed into the KC705.  AH, but when I read that Getting Started anyway, it says that it includes reference designs (page 7).  But does that include example source code?
Can I find example source code somewhere?
Can I find doc that provides info I subsequently provide to MIG, such as the Memory Part# for which it asks, the Memory Voltage and Width (I guess, if custom part), THE INPUT CLOCK PERIOD TO USE, etc?  I'm at a total loss here...
Helmut
muzaffer
@helmutforren have you seen this doc: https://www.xilinx.com/support/documentation/boards_and_kits/kc705/2014_3/xtp196-kc705-mig-c-2014-3.pdf ?
gszakacs
Professor
Professor
Somewhere in the first page of customization for MIG should be a drop-down for selecting a dev board or kit.  There should be an item for KC705 that automatically fills in the correct board information.
-- Gabor
helmutforren
DOH!  But wait, I thought I remembered this after you said so, but now I can't find it.  I'm using Vivado 2015.2 and it's MIG 2.3.
Please help me find it!
1) I created a brand new project. https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html says XC7K325T-2FFG900C.  The closest I could find was XC7K325TFFG900-2. Note I told initial wizard RTL project and to not add sources yet.
2) Then I immediately window / IP Catalog / ... / MIG.
3) When I run it, I get these pages.
>>>NOTE<<< I'm worried about post size.  I'm going to post this so far, then start with another post...
helmutforren
There were no selections to be made on that prior screen.
4) The next screen looks like this:
If I follow through after this, I see no place to provide dev kit.  If I change from "Create Design" to "Verify Pin Changes and Update Design", I do get the following:
But when I click on "Browse", I get
Did it just CRASH?  Is this the path I need to follow and I need to get around the crash?
Or do I need to follow a different path?
Note I was GOING to use k7-embedded-trd-rdf0283\hardware\sources\constraints\k7_emb_vdemo_top.xdc and k7_emb_vdemo_mig_a.prj.  But I couldn't get past Browse.
Although I didn't get a Windows 10 program crash message.  It just went away and I got the error message show.
If I click on User Guide in the bottom left corner, I get a Windows 10 program crash message.  I've found the UG786 for v2.4 separately, and it doesn't say how to pick a dev kit.
MEANWHILE I search k7-embedded_trd_rdf0283...  I find k7_emb_vdemo_top.v, but not even the first module instantiated, k7_emb_vdemo.
muzaffer
@helmutforren the devkit is selected while you create the project, through (parts or boards) option. Did you do this? MIG possibly picks up the board from the project definition.
helmutforren
muzaffer,
Unfortunately, doing as you implied doesn't change anything.  I created a new project and specified the KC705 board rather than the corresponding Kintex-7 FPGA.  The screenshot below confirms this.
Then I immediately tried to add MIG.  It looks IDENTICAL going down the road, including the facts that:
1) If I choose the "Create Design" radio button, then the subsequent options page defaults to Memory Type "Components" rather than "SODIMMs".  This very strongly suggests that the MIG wizard is ignoring the board setting in the project.
2) if I choose "Verify Pin Changes and Update Design" radio button, I get the same crash when I try to browse.  Is this the path I need to follow and I need to get around the crash?
muzaffer
helmutforren
Why, no, I haven't!  Page 19 shows an answer to my original question on this post, about the Memory Part# to use.  I'll follow through with this at my next opportunity, including potentially marking your answer as the solution.
In the mean time, I didn't notice that xtp196-kc705-mic-c-2014-3.pdf on the website for docs associated with the KC705.  Did I miss it?  Or was it not there?  What I REALLY MEAN, is what other docs have I missed?  Do you know any?
Helmut
vemulad
Hi @helmutforren
You will find all User guides and tutorials related to KC705 board here https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html#documentation
Deepika.
helmutforren
Thanks.  Basically I just missed seeing this doc.  I knew about the page.
PROBLEM: When I run the MIG generator, it crashes when I click on "Read XDC/UCF".  The window simply disappears and I get a "failed to generate" error from the Vivado GUI.  This is essentially the same behavior as before, when I clicked "Browse".  This is a MAJOR progress block.  Any ideas?
vemulad
Hi @helmutforren
This is a known issue on windows-8 and Windows-10 platforms.
As a workaround try the below steps:
1. Select "verify pin changes and update design" on first page and select the PRJ file.
2. Rather than browsing and selecting XDC file, type/copy-paste path to XDC.
If you dont have the PRJ file, generate the MIG IP once with default pinout.
Deepika.
helmutforren
Deepika,
Thanks, I thought of that.  And what about the XTP196 MIG instructions for KC705 that want me to go all the way to "Fixed Pin Out" and then read XDC/UCF?  That also crashes.  Must I do create design and attempt to give the correct answers to match the KC705?
I'm using 2015.2 but hope to upgrade to a later version later.  Has it been fixed yet?  (Windows 10 was released July29, 2015.  Surely the newest version fixes this... ... ... ...)
-Helmut
