Anonymous
Not applicable
Floating point adder IP core
                     How to use floating point adder-IP Core in my projects?  I want to have a design in which mantissa part is 18 bits and exponent in 4 bits. I am using Xilinx ISE Project Navigator 14.7.
Thank you
Teacher eilert
Re: Floating point adder IP core
you have to configuure the core using the Coregen tool.
It will start automatically once you add an IP-Core to your ISE project.
There are HDL files provided to instantiate the generated core in your design and use it in simulations too.
See the ISE documentation for details about adding IP-cores and how to use Coregen etc.
Have a nice synthesis
  Eilert
Yes, you can use the Floating Point Operator core which supports custom precision floating point types.
www.xilinx.com
Teacher eilert
  Eilert
Anonymous
Not applicable
               Thank you  I was just checking 'Adders & Subractors' option in Math functions in Select IP window. Just now I found the existance of 'Floating point' option under the same Math functions.
My self being a beginner, do you have any tip for me to write a optimized code, use XILINX ISE 14.7 in best way. Can you direct me to some links?  I find the link http://www.xilinx.com/training/free-video-courses.htm to be too much for me at this level.
Thank you
