For vivado 2013.2, when enable the generate dcp, modelsim can't find the ip core.
I use vivado 2013.2 vesion.
when instantiate a fifo core in design, I choose generate dcp file.
But then run sim, the modelsim will report error info like:
 ** Error: D:/PCIE_IF/sj/tx_engine.v(460): Module 'a_axis_fifo_512x95' is not defined.
if I need do something setting or.....
Thank you!
Re: For vivado 2013.2, when enable the generate dcp, modelsim can't find the ip core.
Thank you for the reply.
I want to know if this problem is fixed after vivado 2013.3?
This issue is fixed in 2013.3
Did you tried in 2013.3 and seeing the same issue.
Satish
