Forcing Out-Of-Context (OOC) IP modules to generate verilog in Vivado 2013.4
      Is there a way to force an import Out-Of-Context (OOC) module to generate code in verilog, instead of vhdl, in Vivado 2013.4?
Elvis Dowson
Re: Forcing Out-Of-Context (OOC) IP modules to generate verilog in Vivado 2013.4
This depends on the project language setting. If it is set to verilog the ip products are geberated in verilog language.
Deepika.
Deepika.
     I have set the project settings to verilog, but Vivado 2013.4 generates vhdl code instead of verilog.
e.g. In my IP sources, I have an IP core called cf_ddsx_1. In the synthesis and simulation folders, instead of a verilog file cf_ddsx_1.v, a vhdl file cf_ddsx_1.vhdl is being generated.
Previously with the EDK-14.7, core generator used to generate *.ngc and *.v files.
Elvis Dowson
Hi Elvis,
What is the IP core you were using?
Refer to product guide of that IP, to see in what language the output products will be generated.
Deepika.
Deepika.
For this specific core as per below PG,  I think by default you will get VHDL behavioral models only.
http://www.xilinx.com/support/documentation/ip_documentation/dds_compiler/v6_0/pg141-dds-compiler.pd...
If you need verilog please try write_verilog TCL option on synthesized netlist, this will give you Verilog Structural netlist.
Follow up from below post
http://forums.xilinx.com/t5/Embedded-Processor-System-Design/Core-Generator-equivalent-for-Vivado-2013-4/m-p/395571#M10480
Vanitha.
