sujeto1
GPIO Pin Number for User LEDs on ZCU102
I am trying to hard-code the pin numbers for user LEDs available on ZCU102 board. how can i hard-code the pin number in my device drivers to on/off the LED.
As the literature says that user LEDs are PL LEDs, and are routed throught EMIO pins. I am unable to resolve the pin-numbet to hard-code in my custom linux device drivers.
tedbooth
Look for Table 3-33 in UG1188 for a listing of the pin numbers for the User GPIO LEDs on the ZCU102 board.
https://www.xilinx.com/support/documentation/boards_and_kits/zcu102/ug1182-zcu102-eval-bd.pdf
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
sujeto1
Thank you for your reply.
According the Table 3-33, UG1188 , User LED 0 is connected to following resurce.
AG14 GPIO_LED_0 LVCMOS33 DS38.2
My question is when i enable the EMIO pin of ZynqMPSOC IP  in Vivado Design enviornment , EMIO [0:95] pin array is available . now which EMIO pin is connected to "AG 14 GPIO LED_0" DS38.2.
AXI GPIO peripheral IP can't be connected to EMIO pin.
