Visitor prophet36
Getting a DCM_SP from COREgen in batch mode?
Usually, I can run the COREgen GUI, select a device and generate a core, then just take the .xco file, rename it to foo.batch, add "NEWPROJECT ." to the top, and then check it into source control, knowing that I can just do "coregen -b foo.batch" to regenerate the core. But when COREgen generates a DCM_SP, it doesn't make an .xco file. The closest is the .cgp file, but that only contains device information; the SELECT, CSET and GENERATE lines are missing.
Is it possible to generate a DCP_SP using COREgen in batch mode?
Chris
Tags (3)
Instructor
Instructor
Re: Getting a DCM_SP from COREgen in batch mode?
"Architecture Wizard" cores should produce a .xaw file which is the equivalent of the .xco
The difference is that you usually add the HDL source to the project rather than the
.xaw file.  So you can regenerate the "core" from the .xaw file using CoreGen, but
you still need to add the HDL output (.vhd or .v) to your project when you're done.
-- Gabor
-- Gabor
Instructor
Instructor
-- Gabor
-- Gabor
Visitor prophet36
Thanks Gábor. Am I right in assuming the architecture wizard will only ever generate a .vhd file, and never an .ngc file? If that's the case then I can just check in the .vhd file generated by the architecture wizard.
Instructor
Instructor
Yes that's true.  The only reason to go back to the wizard would be if you decided to
make changes that are hard to calculate by hand.  Otherwise I normally treat the
output of the wizard (.vhd or .v) as editable source and on't include the .xaw file in
the ISE project.  You might want to hold onto the .xaw file in case you need a starting
point for making major changes.
-- Gabor
-- Gabor
