Hard macro Instantiation
Hi, Please explain in details how can I instantiate a hard macro.
I have create the hard macro and I place it with the rest VHDL/verilog codes.
I was trying to instantiate it as a usual componet/module and the XST (ISE 14.2/nt64) give me the below message
Line 386: Instantiating from unknown module
Can you help me?
Thank you.
Anonymous
Not applicable
Can you post the minimal code for you attempt so far that give you that error message? Pref a 50 line or so example.
below is my component instantiation (hard macro)
Thank you.
my_design my_design(
.signal1_in(in_bits),
.signal2_in(tmp),
.signal_out(tmp_tmp)
Have you included all the required files into the project?
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
I have include my_design.nmc file in the ISE (ise 14.2) project.
In addition, I was trying for a schematic my_design.sym but nothing good happens.
Thank you.
please tell me what other file is requeried expept .nmc?
Thank you.
Regards.
