Help!ISE 10.1 Core Generator,RocketIO GTP can not be generated!
Dear Friends:
     Recently I use the ISE10.1 to fulfill my job.I need to use RocketIO.But there is only RocketIO GTP in ISE 10.1 and I can not generate it by Core Generator.
     Please, help me, I beseech you.Thank you very much!
     The wrong prompt by ISE is :
 WARNING:sim:215 - This core does not support ASY symbol generation.
WARNING:coreutil -  Default charset GBK not supported, using ISO-8859-1 instea
WARNING:sim:93 - NGC output will not be generated for this core.
Finished Generating.
Successfully generated modue_mgt.
ERROR:ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'invalid command name "::Modue_MGT_xmdf::xmdfInit"'.
Tcl_ErrnoId: ENOENT
Tcl_ErrnoMsg: no such file or directory
_cmd: ::xilinx:pm::dpm_chCreateNewSource $piThisInterface
errorInfo: invalid command name "::Modue_MGT_xmdf::xmdfInit"
    while executing
"::${moduleName}_xmdf::xmdfInit aInstance"
    (procedure "::utilities_xmdf::xmdfGetOutputList" line 18)
    invoked from within
"::utilities_xmdf::xmdfGetOutputList $sModule $sFilesDir _XmdfOutputList"
    (procedure "dpm_coregenGetOutputList" line 23)
    invoked from within
"dpm_coregenGetOutputList $sCoreModuleName $iProject $sCoreDir _genList"
    (procedure "dpm_coregenCreateCore" line 50)
    invoked from within
"$_sCreate $_filePath $_iNewSourceComp _OutputFileList"
    (procedure "::xilinx:pm::dpm_chCreateNewSource" line 61)
    invoked from within
"::xilinx:pm::dpm_chCreateNewSource $piThisInterface"
Re: Help!ISE 10.1 Core Generator,RocketIO GTP can not be generated!
Interesting!!! A few minutes ago I used the Core Generator, too, to create a Single Port Block RAM and got a similar error message. But right before the error message occurs the console says: "Finished Generating". So I guessed it's actually generated, although I could not see it in the project sources. I took a look in the project folder and found the generated files. So I tried to add them manually to the poject sources which works for me. Maybe it works for you, too, gaochaoant.
My Console output:
Customizing IP...
Finished Customizing.
Generating IP...
Generating Implementation files.
Generating the VHDL wrapper.
Generating ISE symbol file...
Generating NGC file.
Successfully generated progMem.
ERROR:ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'invalid command name "::ProgMem_xmdf::xmdfInit"'.
Tcl_ErrnoId: ENOENT
_cmd: ::xilinx::Dpm::dpm_chCreateNewSource $piThisInterface
errorInfo: invalid command name "::ProgMem_xmdf::xmdfInit"
    while executing
    invoked from within
    invoked from within
    invoked from within
    (procedure "::xilinx::Dpm::dpm_chCreateNewSource" line 61)
    invoked from within
"::xilinx::Dpm::dpm_chCreateNewSource $piThisInterface"
     Thank you for your message!
     But it can not be effective in my ISE.
     Before the last message,My console prompts:
     Customizing IP...
    10.1.03 - Xilinx CORE Generator IP GUI Launcher K.39 (nt)
    Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
    Generating IP...
     I find that it seems that all GTP IP can not be generated no matter in which ISE.
Message Edited by gaochaoant on 02-11-2009 05:12 PM
Do you use different names for File Name (in 'New Source Wizard ...')  and Component Name (in 'Core Generator Wizard')? Choosing the same name for both fixed the problem for me, I didn't get the error message anymore.
Message Edited by jdinse on 02-12-2009 09:49 AM
Message Edited by jdinse on 02-12-2009 09:50 AM
