How can I get IPIC IP?
Dear Supporters,
I have a success with IPIF as packaging IP. But it's differ from my expectation.
My IPIF seems like just one slave AXILITE peripheral IP. this seems like that it made from Create AXI4 Periphral.
I though that the IPIF was including IPIC as below image.
But my IPIF IP have not any export ports like above red box.
So I want to know how to involve that IPIC into my IPIF ip.
Is this need any particularly methods? would you please give to me any hint?
check this document
http://www.ioe.nchu.edu.tw/Pic/CourseItem/4753_40_Creating_and_Adding_Custom_IP.pdf
Thanks and Regards
Balkrishan
check this document
Thanks and Regards
Balkrishan
