How can I impliment this formula??
I am a newbie.
    I don't know how to implement the following formula in VHDL .
    And I don't know how to make the derivative of X.
    Formula:  x's derivative=9*(x-5)+7;
Scholar drjohnsmith
Re: How can I impliment this formula??
thats a general question,
and I'm afraid it's a long road to get the answer.
You could just write
deri <= 9 * ( deri - 5 ) + 7;
BUT
that makes a lot of assumptions.
 Like:
what size / format is deri ?
I'm assuming you have this in a clocked prosess ?
size off the numbers, which bits of the numbers do you want to take, remember your in the hardware world now, so you have to decide how many bits you want, not what the cpu gives you.
Take big step back, I guess you need to learn a lot of hardware design before you go forward.
Thanks for your reply. But there are some misunderstanding between us.
I will explain the formula to you.
First,assume a variable is 10 bit  whose name is X.
The derivative of X equal to 9*(X-5)+7.
How can I get the result of the variable X?
Scholar drjohnsmith
Well Ok, lets split this out for you:
A <= X - 5;
B <= A * 9;
C <= B + 7;
X <= some_bits_of( C );
What size is A,B abd C going to be ?
you then need to re size C back to 10 bits to assign it back to X.
Ahh, all these things you don't have to worry about in the world of C,
  but unfortunatly in hardware, it's up to you to specify the size of bits used, and where the decimal point goes.
e.g. you could, but I would not, specify A,B and C as floating point 64 bits numbers, it's what a CPU would do, but that would be an Amazing waste in hardware !
so right out the maths you want done, and think how many bits and where you want the decimal point to go.
Yeah,sir.You are right that I have to consider the width of the data which is inevitable in hardware.
All the data in my programme is integer.  In that case ,I don't need to care about the point.
I j wonder how can I deal with some_bits_of ??
Scholar drjohnsmith
Ok, so integers,
so what size do we need say A to be ?
example, say x = 3, what would that make A ?
to get your required bit width:
x-5: 11 bits assuming min(x)=-512
9*(x-5): 14 bits
9*(x-5)+7: 14 bits
You can verify this (or correct me) by filling in the max and min numbers that X can take. I guess X inside [+511, -512] for 10 bit integers, so the formula will result in the derivative being inside [+4561,-4646]. To represent these numbers you need 14 bits or a range [+8191, -8192].
To shrink the bit width of the derivative, you probably want to read up on saturation, truncations, etc. to avoid nasty numerical side effects.
Cheers,
Johan
Thanks sir. With your help ,I know how to determine the width of the data .
But I still unsure how to get the value of X in the formula. Could you give me some advice about that?
Historian
Historian
Integration?
Review differential equation solving?
Cheers,
Johan
Advisor eilert
Advisor
Hi ,
your question is a little confusing.
Ok, you have this formula:
so what's your input signal and what's your output?
If yor Input is X then you (simplified) calculate:
 derivative<=9*(x-5)+7;
Like it was mentioned in one of the first replies.
If X is the Output and derivate the input then the formula changes to:
 x <= ((derivate - 7)/9)+5;
where you get some problem with synthesis, since 9 is no power of two result.
So, what are you about to do?
Can you provide us with some entity or process template where we can see what 's declared and how the data flow is intended to be?
Have a nice synthesis
  Eilert
Observer eneserdin
You mean integration as i understand and in the previous replies it was asked. The exact explanation of the problem is
d(f(x))/dx = 9(x-5)+7
what is f(x), you meant this, didn't you?
if it is a specific function like above then it is a paper & pencil work.
f(x) = 9/2*x^2 - 38*x + C
But, you must specify your boundaries. However, if the equation is not a specific one like above then you have to study on taking integral in discrete domain.
