How can I use the the function of cross probe when I synthesize and implement my design using command lines
I used to synthesize and implement my design by ISE GUI, and the function of crossing probe is very convenient and useful. For example, when I generate a timing report, I can right click those paths, which have been highlighted, and see them in technology view and so on. But now I start to implement my desing using command line, which has mang advantages. Generally, I will write the batch files which contain the command line and use it to implement my design. But I also find that I cannot use the function of cross probing after the timing report is generated since there are no paths which have been highlighted. So I want to know how can I continue to use that cross probe function when I synthesize and implement my design using batch files.
Mike
