How do I access the quad SPI through the SPI IP on data lines D4-7 after configuration?
My design is using a Kintex Ultrascale part, xcku040-ffva1156. I am using two Micron N25Q256A SPI parts in my design for a x8 configuration. I am able to generate the required two bin files for programming. I can program both parts using the hardware manager. On power up configuration occurs properly with the two SPI parts and the design works. I have the AXI QUAD SPI IP in the design to be able to write to the SPI parts. It is configured with flash access through startup primitive selected.
The SPI IP provides a slave select output which I have connected to the other SPI part (qspi_fcs2_b, G26) not connected to the startup primitive. The other SPI part is connected to data pins D4-D7 (M20,L20,R21,R22). Using the C code (flash_qspi_rw.c) found xapp1280 I am able to program the SPI part that is connected to the startup primitive through the SPI IP using the Microblaze. However I cannot program or access the other flash. I changed the flash_qspi_rw.c to select bit 1 in the slave select register for the other flash but access does not seem to happen. I looked at the routing and it looks like there is no routing to data pins D4-D7. I also have no reference in my design connecting anything to data pins D4-D7. I assumed that the SPI IP was handling that.
So how are data pins D4-D7 supposed to be connected to allow access to the other flash?
Community Manager
Community Manager
Re: How do I access the quad SPI through the SPI IP on data lines D4-7 after configuration?
AXI Quad SPI IP supports x1,x2 & x4 modes only. To interface SPI IP in x8 mode, you should either make use of two AXI Quad SPI IPs or share one AXI Quad SPI IP between the two flashes and play with clock/CS to switch between the two IP while R/W.
Community Manager
Community Manager
