How specify clock frequency for VIO IP (Vivado 2016.4)
I get this message
[Timing 38-316] Clock period '10.000' specified during out-of-context synthesis of instance vio at clock pin 'clk' is different from the actual clock period  this can lead to different synthesis results.
Where do I specify this clock period? I tried editing the ooc xdc file, but that was overwritten when I regenerated the IP.
Re: How specify clock frequency for VIO IP (Vivado 2016.4)
Hi @bcarltontrex
Try the method described in page-30,31 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug896-vivado-ip.pdf
Deepika.
Hi @bcarltontrex
Deepika.
That helped. The specific property wasn't one of those listed in the document, it was CONFIG.SIGNAL_CLOCK.FREQ_HZ. Sample command:
  set_property CONFIG.SIGNAL_CLOCK.FREQ_HZ 161000000 [get_ips vio_wide_input]
  I created fifo_generator_0 in vivado. I need to work under 125MHz. I started 125 MHz there. At synthesis I receive the warning.
[Timing 38-316] Clock period '10.000' specified during out-of-context synthesis of instance 'fifo_generator_0' at clock pin 'rd_clk' is different from the actual clock period '8.000', this can lead to different synthesis results.
I set the Tcl command
1. set_property CONFIG.CORE_CLK.FREQ_HZ 125000000 [get_ips fifo_generator_0]
2. set_property CONFIG.READ_CLK.FREQ_HZ 125000000 [get_ips fifo_generator_0]
3. set_property CONFIG.WRITE_CLK.FREQ_HZ 125000000 [get_ips fifo_generator_0]
1-st works, 2-nd and 3-rd do not work and they do not give errors.
File  fifo_generator_0.xci  after executing commands
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CORE_CLK.FREQ_HZ">125000000</spirit:configurableElementValue>
        <spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.MASTER_ACLK.FREQ_HZ">100000000</spirit:configurableElementValue>
        <spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.READ_CLK.FREQ_HZ">100000000</spirit:configurableElementValue>
        <spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.SLAVE_ACLK.FREQ_HZ">100000000</spirit:configurableElementValue>
        <spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.WRITE_CLK.FREQ_HZ">100000000</spirit:configurableElementValue>
What am I doing wrong? how do I get the parameters changed?
With regards, Sergey.
get_property CONFIG.READ_CLK.FREQ_HZ [get_ips fifo_generator_0]
100000000
get_property CONFIG.READ_CLK.FREQ_HZ.value_src [get_ips fifo_generator_0]
user
125000000
100000000
