How to add inverter, buffer, and other logic block by IPI?
Hi:
I'm using IPI tool in Vivado to create a system.
For some reason I need to add a buffer and a inverter in the block diagram.
But I can't find such IP in the IP catalog.
How can I add such logic into block diagram?
The other question is, I tried to connect the on board reset pin to both the reset pin in clocking wizard IP and MIG7 IP.
But there'll be error message :
ERROR: [Synth 8-3257] port <RSTN> has illegal connections. This port is connected to an input buffer and other components.
Input Buffer:
Port I of instance \u_system_mig_7series_0_0_mig/u_iodelay_ctrl/u_sys_rst_ibuf (IBUF) in module <system_mig_7series_0_0>
Other Components:
Port I1 of instance i_20 (LUT2) in module system_rst_Clk_100M_0
How should I solve such problem?
Thanks!!
David
Re: How to add inverter, buffer, and other logic block by IPI?
Regarding the error message, it looks like the reset port is driving an IBUF and LUT as shown below.
Port  --> IBUF (with in MIG) --> MIG logic
         --> LUT input pin
It should instead be
Port --> IBUF --> MIG logic
                      --> LUT input pin
Deepika.
Deepika.
You can use Utility differential IO buffer and utility vector logic IP's to add buffer and inverter respectively in block design .
Deepika.
Deepika.
         --> LUT input pin
                      --> LUT input pin
Deepika.
Deepika.
Hi @ccmake23
Did that help?
Deepika.
Deepika.
Hi Deepika:
Thanks for your info, it works.
BTW, for the reset port error, is the rule that I shouldn't connect a port to a BUF and other circuit at the same time?
Any reason why?
David
Yes, the IBUF should be driving the logic. You cannot have port directly driving the IBUF and logic (with out IBUF in the path).
Deepika.
Deepika.
Got it!
Thanks a lot! :)
Hello.
This may be obvious, but I can't see it.
Can I use an input vector width of 1 with the XOR function to make an inverter?  If not, how do I split up the input vector to drive the bits separately?
Thank you.
Teacher muzaffer
xor of identical inputs doesn't make an inverter 1^1 is zero but 0^0 is also zero. nand on the other hand works: nand(1,1) is zero and nand(0,0) is one.
Thanks for posting.  I found my error.  I was using Utility Reduced Logic when I should have been using Utility Vector Logic, which has an inverter.
