Visitor majunwei
How to change internal parameters in IP block design?
I'm wondering if it is possible to change internal parameters in IP block design or integrator?
For example, if I want to change internal settings of the axi crossbar inside the axi interconnect, is there a way to manually change it instead of using automatic detection?
so my question is will I be able to use TCL command to change the internal infrastructure cores inside an IP instead of using automatic detections?
Jeremy
