Visitor parimal55
How to compile ABEL code project in Xilinx ISE 10.1 with service pack 3
We are trying to compile ABEL code roject in Xilinx ISE 10.1 service pack 3. However, we are not able to see Synthesis tool as ABEL in ISE 10.1.We have ABEL and UCF file and we are using CPLD device.
Can you help us to compile the ABEL code?
Re: How to compile ABEL code project in Xilinx ISE 10.1 with service pack 3
Hi @parimal55,
Are you able to add ABEL file in your project? (As shown below, click on "open" icon and select options for ABEL and UCF)
hemangd
Visitor parimal55
Hi I am able to add ABEL and UCF file. Not able to synthesis in the tool ISE 10.1
Hi @parimal55,
What error are you facing? provide snapshot.
Also provide ABEL file to check it at my end.
hemangd
Visitor parimal55
Pease refer picture herewith. Cant provide ABEL code. Just want to know procedure for compilation for ISE 10.1
Hi @parimal55,
ISE tool does not directly synthesize abel file. First it must be converted into VHDL or Verilog file which can be done using the command called ‘XPort’.
Have a look into this AR.https://www.xilinx.com/support/answers/17000.html
hemangd
Hi @parimal55,
Let us know if you have further queries on it, or close this thread by marking it as accepted solution.
hemangd
Visitor parimal55
We are getting errors in converting ABEL to VHDL. Please find attached pitcures for details.
Hi @parimal55,
From the error description, it seems to be a syntax error in your .abl file, hav eyou tried to correct them?
Raj
