How to create a user IP with both AXI4 & AXI4LITE protocols
I've created two user IP peripherals based on AXI4 and AXI4LITE protocol respectively by using the CIP (Create and Import Peripheral) Wizard. And I've also merged them into one single module. Here comes the puzzle of modifying MPD file, with which I don't know how to deal.
Parts of Declarations of Bus Interface, Related Parameters and Ports  for the IP based on AXI4LITE
## Bus Interfaces
BUS_INTERFACE BUS = S_AXI, BUS_STD = AXI, BUS_TYPE = SLAVE
PARAMETER C_S_AXI_PROTOCOL = AXI4LITE, TYPE = NON_HDL, ASSIGNMENT = CONSTANT, DT = STRING, BUS = S_AXI
## Ports
PORT S_AXI_ACLK = "", DIR = I, SIGIS = CLK, BUS = S_AXI
## Bus Interfaces
PARAMETER C_S_AXI_PROTOCOL = AXI4, TYPE = NON_HDL, ASSIGNMENT = CONSTANT, DT = STRING, BUS = S_AXI
## Ports
I am wondering if the parameter C_S_AXI_PROTOCOL, I don't know,  may be a dedicated parameter in the specified IP.
If I create a new mpd file for my user IP with both AXI4 & AXI4LITE bus interfaces, how would I describe the parameter C_S_AXI_PROTOCOL to make the XPS recongnize the two different buses, or may there be another way resolving this problem?
(I 've tried some ways to process it, but all failed..., I am looking forward to the reply.)
Ting
Re: How to create a user IP with both AXI4 & AXI4LITE protocols
Thanks!
Ting
