Scholar ronnywebers
How to create your own custom board files for Vivado?
Is there any information available on how to create your own board files? i.e. to setup DDR4 memory, some fixed interfaces on the board, have drop down boxes for LEDs, switches, other interfaces, ...
In general I can see 3 files associated with (eval) boards like the Zedboard, Picozed, ZCU102, ...  :
* board.xml
* part0_pins.xml
* preset.xml
So I'm looking for info on the syntax, naming conventions, all possible parameters that can be put into these files, ... . Are there any templates to start from, or do people start from an eval board that resembles a bit your own board, or ... ?
Re: How to create your own custom board files for Vivado?
@ronnywebers
Check Appendix A in below UG:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug895-vivado-system-level-design-entry.pdf#page=100
You can take existing board files in the XIlinx install directory as reference :
<install_dir>/Vivado/<version>/data/boards/board_files/
--Syed
Hi Ronny,
I havn't created board files before.  However, I see that Appendix-A of UG895 has quite a lot of information.
Cheers,
Mark
@ronnywebers
--Syed
