evrenyork
How to disable partial reconfiguration wizard?
Hi All,
I have a problem about disabling the partial configuration. I clicked Tools->Enable Partial Reconfiguration Wizard by mistake in Vivado 2018.3. Now, I couldn't disable it and use Create and Package New IP wizard. When I click the "Create and Package New IP", vivado gives a message which is "Packaging a project with partial reconfiguration enabled is not supported."
I found a topic about enabling "Enable Partial Reconfiguration Wizard" and tried to use a TCL command from the solution but it does not work.
The solution topic is https://forums.xilinx.com/t5/Vivado-TCL-Community/Vivado-2017-1-Enable-Partial-Reconfiguration-will-make-the/td-p/765522
set_property pr_flow 0 [current_project]
It gives an error message which is
ERROR: [Vivado 12-4760] Can't be changed once PR_FLOW property is set to true
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
So, how can I disable it?
Evren
rshekhaw
Hi @evrenyork ,
At the starting of converting a project into PR, tools pops up a warning:
From the pop up message itself, it is clear that it can't be undone.
Raj
