How to enable locked IP?
Hi All,
After migration from Vivado v2015.4 to v2016.2, I've got locked IPs in the project.
After running the 'report_ip_status' command, I've got the following:
So, the recommendation is to Enable the locked IP. How should I do so?
Thank you!
Re: How to enable locked IP?
Hi @dmitry1417
1. Go to Tools --> Report --> report IP status
2. Select the IP's which are locked and select "Upgrade IP's"
Deepika.
An another way is to right click on the xci file of the IP in the IP Sources tab and enable it. Thank you!
