How to export from lower version (2013.3) to higher version 2014.1
Hi All,
I tried by opening 2013.3 design in 2014.1and gave upgrade IP. But they were not updated and I am not able to customize them.
What is correct procedure to export the Vivado block design from 2013.3 to 2014.1 and use the IPs properly?
Vinod
Re: How to export from lower version (2013.3) to higher version 2014.1
Hi Vinod,
Please check "Migrating IP Integrator Designs from One Release to Another" of below UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug994-vivado-ip-subsystems.pdf
Is your design packaged IPs and processors please also refer "Limitations to Packaging the Block Design"
Hope this helps
Vanitha
Hi Vinod,
Hope this helps
Vanitha
Did you face any errors or warnings when upgrading the ip's?
Deepika.
Deepika.
