How to export the memory data from the bit file ?
Hi Friends,
I have only  bit file {contains processor+ BRAMs + other design}, is it possible to export the BRAM data to a file from that bit file.
NOTE : using either vivado/ISE.
Any help or suggestions are highly appreciated.
Thank you
S Sampath
-Sampath
Mentor
Mentor
sorry, there are no tools that will do this easily.  At best, you can find some tools that give info about the bitstream (date, part number, etc).
Mentor
Mentor
Hello @ssampath,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
