Voyager
Voyager
How to export the memory data from the bit file ?
Hi Friends,
I have only  bit file {contains processor+ BRAMs + other design}, is it possible to export the BRAM data to a file from that bit file.
NOTE : using either vivado/ISE.
Any help or suggestions are highly appreciated.
Thank you
S Sampath
-Sampath
Mentor
Mentor
Re: How to export the memory data from the bit file ?
sorry, there are no tools that will do this easily.  At best, you can find some tools that give info about the bitstream (date, part number, etc).
Mentor
Mentor
Hello @ssampath,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
