Participant kirito0816
How to find the nets with the DONT_TOUCH attribute
I followed the timing closure introduction and used the commend "report_fail_fast" to get the report . Then I found there were 1300s nets with attibute DONT TOUCH. However, I remember I did not add this attribute to any net. And I cannot find the word "DONT_TOUCH" in my code. I wonder how can I know which net has this problem?Thank you.
Re: How to find the nets with the DONT_TOUCH attribute
@kirito0816
What are the other REVIEW items in failfast report apart from DONT_TOUCH? Did you try applying different strategies to meet timing? Also check the report_qor_suggestions.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug906-vivado-design-analysis.pdf#page=54
FYI: I would suggest not to remove the DONT_TOUCH on nets which are inside IP.
In general if you want to remove the DONT_TOUCH on high number of nets then you can use the wild cards else after getting the objects with "show_objects -name find_1 [get_nets -hierarchical -top_net_of_hierarchical_group -filter { DONT_TOUCH == "TRUE" } ]" select the nets (CTRL+ ) and then use then use the following command: set_property DONT_TOUCH 0 [get_selected_objects ]
--Syed
@kirito0816
Open the implemented design and run the following command from TCL console which should list all the nets which has DONT_TOUCH attribute set to true:
The attribute must be coming from IPs in your design.
--Syed
Thank you. I found these nets do come from IPs, like DDR and FIFO. Is there any way to reduce them? Because the "DONT_TOUCH (cells/nets)" option in fail_fast report is high.
@kirito0816
--Syed
