How to insert a OBUF in vivado's block design?
Hello all,
  At the top level I have the following
      asig : out std_logic;
      asig <= bsig;
     ablock_i ablock
     port map (
        a => bsig;
  Have created an IP for ablock and trying to connect ablock but can't find obuf in the IP catalog to do the connect from bsig to asig. Can you please let me know how can I do this?
Best regards,
Fred
Re: How to insert a OBUF in vivado's block design?
You need not connect it to OBUF. Right click on the cell pin and select "make external".
When you run synthesis the tool automatically infers the input and output buffers.
If you want to insert differential buffer then use "utility differential io buffer" ip present in block design.
Deepika.
Deepika.
The tool automatically inferrs this but in addition why can't you write the OBUF instance in the top module.
Anirudh
Hi @fsahebi2014
Did that help?
Deepika.
Deepika.
Hi Deepika,
  Would it be possible to call you and discuss this with you?
Regards, Fred
Hi Fred,
Please post your queries here, we will try to answer them.
In case if you have webcase access feel free to open a webcase.
Deepika.
Deepika.
Hi Deepika,
  How can I access webcase?
Regards, Fred
You can log a webcase at http://www.xilinx.com/support/clearexpress/websupport.htm
Incase if you dont have webcase access you can contact your distributor for help.
Deepika.
Deepika.
There is many questions that I have so what's the best way to ask? Can I give you my company's email. It will take a long time to figure it who the software we bought it from becuase the accounting person is on vacation.
Regards, Fred
