How to install patch file for Vivado2018.2
I am using Vivado2018.2 and the operation system is window10(version:1809).
I create the block design in Vivado and then launch to SDK. Then I create the lwip echo server example application in SDK.  The application is automatically bulit by SDK after it is created.  Then I got the following errors:
I tried to find answer on the forums and refer to AR#71330( https://www.xilinx.com/support/answers/71330.html) which shows that it seemed to be a version problem.   AR#71330 also provide the patch file.
However, I don't know how to install that patch file. ( I mainly referred to  AR#53821 https://www.xilinx.com/support/answers/53821.html)
It almost took me a whole day to find the way to install that patch, still failed. Could anyone give me some advice?   If possible, I want to know the step-by-step approach to install that patch file for Vivdo2018.2. Thanks!
Re: How to install patch file for Vivado2018.2
Hi @liumeiyan
The easiest way is to replace the file in you installation directory with the file from the github with the same commit:
https://github.com/Xilinx/embeddedsw/blob/62c4cb08aeea606ccd2845f337b078f9137d5c29/ThirdParty/sw_services/lwip202/src/contrib/ports/xilinx/netif/xadapter.c
Or you can download the full repository and checkout this commit, then add the folder in the repositories for SDK.
