How to know a repository of IP? What's the TCL command to report it?
Hi All,
How could I know a physical repository location of IP?
Is there a TCL command, which might be used to report a repository location of IP in Block Design?
Thank you!
Re: How to know a repository of IP? What's the TCL command to report it?
Hi @dmitry1417,
To know the repository of an IP if you know its name in the IP calatalog (example with the Xilinx IP DisplayPort 7.0):
get_property REPOSITORY [get_ipdefs *displayport:7*]
If you want to get it using the IP name from the BD:
get_property REPOSITORY [get_ipdefs [get_property IPDEF [get_ips *MYDP_RX*]]]
Is it what you need?
Florent
Florent
@dmitry1417,
The below command will display the repository location:
get_property  ip_repo_paths  [current_project]
--Syed
Hi @dmitry1417,
Could also be:
get_property IP_DIR [get_ips *IP_NAME*]
Florent
Florent
The get_property IP_DIR [get_ips *IP_NAME*] gives the IP location in the Block Design.. But actually the IP is located (and packed to) another directory outside of the project - it was just added to the Block Design.
I'm actually need to know/report what's the original location of the IP. So, how to report it? How to report the repository where the IP was packed to?
Hi @dmitry1417,
Florent
Florent
