danewhome
How to maintain IP/BD OOB xdc and USER xdc
How do user know IP or BD build-in constraints and prevent double constrain action in user's USER.xdc file?
rshekhaw
Hi @danewhome ,
You can find the xdc of BD in source tab itself:
Raj
viviany
IP/BD constraints take care of any prioprity or conflicting issues that might happen with the user constraints.
Ideally user does not need to care about the constraints for IP/BD, just needs to add constraints for user logics in user.xdc.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
syedz
@danewhome
Check constraint file processing order:
https://china.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug896-vivado-ip.pdf#page=38
Also check Constraint Files Order with IP cores.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug903-vivado-using-constraints.pdf#page=14
--Syed
