Participant kp1998_
How to obtain verilog code from IP core
Hello
How can I generate verilog HDL code from an IP core component.
For example I am working with fir filter so I create a design by selecting FIR_COMPILER component from IP catalog, provide the required coefficient values and generate main module and test bench from it. But the main module and test bench code generated is in VHDL not in verilog. I am trying to change it into verilog but not able to do.
Please help with this.
Waiting for thr reply at the earliest.
Thank you
Re: How to obtain verilog code from IP core
Hi @kp1998_ ,
I guess you cannot achive that. If you check the FIR COMPILER IP user guide the design files are firstly encrypted and are in VHDL only:
Raj
Participant kp1998_
ok
Hi @kp1998_ ,
Do you have further queries on this? If not, please close this thread by marking it as accepted solution.
Raj
Participant kp1998_
So for all the components present in IP catalog verilog code cannot be generated or is it only for FIR_COMPILER component.
Thank you
@kp1998_
It is possible to mix VHDL and Verilog as shown in chapter 9 of UG901.  Have you already tried this mixing?
Mark
Hi @kp1998_ ,
Thie information i shared was specific for FIR COMPILER. If in your BD there are other different blocks and in then if there are Xilinx IP blocks, you can check the Table as mentioned for FIR, in User guide of that IP whether Verilog is mentioned or VHDL is mentioned or both are mentioned.
Raj.
Participant kp1998_
Ok Can u please share that user guide, will be of great help
Thank you
Participant kp1998_
No i havent tried mixing cause i dont know VHDL language and i want to use only verilog because the other codes i have written using verilog only as i need to combine this particular code with the other ones.
Thank you
You can search for the IP "Product Guide" on xilixn.com by searching the IP name.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Which language being used for the IP really doesn't matter, unless that your simulator does not support mixed language simulation.
The IP is provided as a package. It comes with the instantiation template, GUI customization wizard, Product Guide for the interface and function details. You don't need to read the IP code.
I'm afraid most of the IPs come with VHDL.
What is your concern of using VHDL for the IP?
-vivian
