How to properly add generic to Xilinx ISE Schematic?
I'm using Xilinx ISE 14.7 Project Navigator Schematic entry to add a VHDL module that defines a generic.   However, when I Systhesize the project I get the following error.
ERROR:HDLCompiler:1314 - "/home/ise/ise_projects/PFAL_AIU_FPGA/Top_Level.vhf" Line 1929: Formal port/generic <divider> is not declared in <clock_divider>
The VHDL file contains the following generic:
entity clock_divider is
  Generic ( divider : integer := 8000000);
  Port ( clk_in : in  STD_LOGIC;
           clk_out : out  STD_LOGIC);
end clock_divider;
I've also added and Attribute to the schematic entry block as 'divider' with the integer value '8000000'
I found that when you generate the Implement the Top Level module for the schematic it leaves out the generic for the VHDL component.
How do I get the tool to generate the generic for the VHDL component?
Re: How to properly add generic to Xilinx ISE Schematic?
Hello @carljwhite3
Kindly check https://www.xilinx.com/support/answers/12062.html
Bhushan
Hello @carljwhite3
Bhushan
As a side note.
Not many people use the schematic entry system, its deemed old fashioned.
If your learning, dont go down the schematic route.
Ran into a problem after following soultion that was resolved by following another solution: https://www.xilinx.com/support/answers/18909.html
