How to run lab1.tcl files
I have download zip file in this web site(user guide)
It is may be example files
How to extract this file?
It have no explained in this file!
Mentor
Mentor
Re: How to run lab1.tcl files
Hi @ghkdkrtks
I'm not familiar with lab1.
But I guess it is correct procedure as below.
1. Extract zip file.
2. Run vivado
3. enter the following command on vivado's console.
source <your extracted zip directory>/lab1.tcl
Best regards,
Mentor
Mentor
Hi @ghkdkrtks
2. Run vivado
Best regards,
Thanks!
Following is correct!
source d:/2/lab1.tcl
