How to save the "messaging.defaultLimit" parameter in a Vivado project?
Hello, and thanks in advance for reading. By default, Vivado limits the number of occurrences of any individual message that it will display to 100, after which it will print, "Message X appears 100 times and further instances of the messages will be disabled..."  AR# 53034 states: "To increase the default message limit for all the message IDs, use the TCL command set_param messaging.defaultLimit..."  This is working for me, but I need to save this setting to the Vivado project so that it will be in effect when other members of my team use the project.  Can anyone enlighten me on how to accomplish this?
Thanks again,
Dave
@dsammel,
Save the command in a init.tcl file and keep it in the scripts folder (C:\Xilinx\Vivado\2016.3\scripts). -- This will enable the command everytime Vivado is launched.
Or you can put it in synth pre.tcl in Synthess settings.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
@dsammel,
Nupur
Hi @dsammel,
To complete @nupurs response, please look at AR#53090 (link). There are information about the init.tcl file
Thank you both! This is exactly what I needed.
