How to specify output of encryption
Are there any possible way 'encrypt' TCL command to output a speific file instead of replaceing the source?
TCL> encrypt -lang verilog -key ${KEY_FILE} -ext .vp ../../my_dir/my_file.v
This command generates ../../my_dir/my_file.vp.
Instead I want to specify the output file something like './my_file.vp' in the different directory.
Re: How to specify output of encryption
According to the manual (UG835), 'encrpyt' command does not have any options to specify its output. Most of all, the original file is updaed if '-ext' option is not given and it can make lost of the file.
This is why I posed this question.
I see. Thanks on your comment.
@andoki
I guess specifying an output directory for the encrypt command is not possible
please refer the following link
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug835-vivado-tcl-commands.pdf#page=486
--Suraj
