pavel_47
How to start with Vivado in Linux
Can someone provide me a link how to start with Vivado on Ubuntu.
The launcher is in /tools/Xilinx/Vivado/2020.1/bin
It's is not visible out of this location. Probably should I modify some configuration files
Moreover is there a way to put Vivado icon on Favorites ?
Thanks in advance.
Pavel.
joancab
Google for  "ubuntu create launcher icon" and you will get about a thousand solutions, maybe 200 of them for your specific release, and possibly a hundred of them not working or badly explained. It's how it is.
There are even videos that show you in 20 minutes what can be written in 2, but writing and reading seems to be highly intellectual activities nowadays.
pavel_47
Running
source /tools/Xilinx/Vivado/2020.1/settings64.sh
fixes the issue with launching Vivado from everywhere
pavan_619@
It is good that it is running
Alternate method:) if you want
Instead of using every time source command you can add that command in bashrc file
vi ~/.bashrc or gvim ~/.bashrc
save the bashrc file
source ~/.bashrc
After that you can directly use
vivado
This command it worked for me.
Enjoy your day.
Pavan
whitehorsesoft
The suggestion for running `settings64.sh` is reflected in the note on page 9 of UG893 Using the Vivado IDE:
TIP:To add the Vivado tools path to your current shell/command prompt, run settings64.bat or settings64.sh from the <install_path>/Vivado/<version> directory.
