Observer rganesaa
How to use `define statement
Dear Sir/Madam,
I am trying to use `define statement in system Verilog to define global constants and functions. I am using Vivado 2015.2 64 bit edition. After writing a lengthy program, I found while the program works well with parameter replacing parameter with `define macros does not work. Hence I have written the following small program to check my understanding of `define macro.
Following is the source code:
// Module Name: NoC_Example_include
//`define PI 3.1214
module NoC_Example_include(input o1);
wire [31:0] o1;
endmodule
Following is its test bench:
`timescale 1ns / 1ps
`define PI 3.1214
module tb_NoC_Example_include();
reg [31:0] o1;
NoC_Example_include  N1(.o1(o1));
initial
begin
o1=PI;
$monitor ("o1 = %d",o1);
end
endmodule
I expected the program to print out o1 = 3.1214. The program does not run with error message: PI is not declared.
Moving PI from test bench to main module where it should be anyway does not help either.
Any help in diagnosing why the program is not giving expected results will be deeply appreciated.
Thanking you,
Yours sincerely,
R. Ganesan.
Teacher muzaffer
Re: How to use `define statement
you need to say
o1 = `PI;
Teacher muzaffer
you need to say
o1 = `PI;
Observer rganesaa
Thank you muzaffer.
You are always available and your replies are on dot.
Apart from missing 'PI it required PI to be defined in both main module and test bench.
Historian
Historian
I just want to point out that
a) PI is not equal to 3.1214
b) assigning a non-integer number to a reg is pretty much meaningless...
Avrum
Observer rganesaa
I agree.
Oversight. PI 3.1412
The idea was to check how to use 'define statement, yet your comments are valid.
