Voyager
Voyager
How to use revision control systems?
Hi, we would like to start a revision control approach.
We never worked as a team, every designer has a project,once in a while, we share the IP's or the progress made by a designer to the rest uf the team.
What could be a system that works well for us?
Scholar pratham
Re: How to use revision control systems?
@mrbietola There is a good video and XAPP for revision control system please refer them
http://www.xilinx.com/training/vivado/using-vivado-design-suite-with-revision-control.htm
http://www.xilinx.com/support/documentation/application_notes/xapp1165.pdf
-Pratham
Scholar pratham
-Pratham
Which version and SW (Vivado/ISE) are you using?
Tushar
Voyager
Voyager
Thanks for replies , we are using Vivado 2015.2
@mrbietola,
I believe the information provided above by @pratham is good enough to understand revision control with Vivado.
Please refer them and let us know if you have any more queries.
--Syed
