I am using ISE on AMD 64 bit
I am using ISE 14.6
on AMD 64 bit linux
I get the message:
Architecture behavioral of Entity a is up to date.
/opt/Xilinx/14.6/ISE_DS/ISE/bin/lin64/unwrapped/xst: symbol lookup error: /opt/Xilinx/14.6/ISE_DS/ISE//lib/lin64/libCs_DeviceHelpers.so: undefined symbol: _ZN11Cs_Internal20DbgTracerInitCounterD1Ev
Please advise
thanks
Dag
Re: I am using ISE on AMD 64 bit
Th *.so file mentioned in error looks corrupt.
If you have any successful installation of ISE on another machine copy *.so file to this system.
Also you can try to re-install the software.
Yash
Hi @dag1,
This error can come up if the XST libraries fail to get loaded.
As a workaround you can use the LD_PRELOAD variable which can be used to load the required libraries (.so files)
setenv LD_PRELOAD /proj/xbuilds/ids_14.6_O.61xd.0.0/lin64/14.6/ISE_DS/ISE//lib/lin64/libXst_Core.so
Rajesh
Hello and thanks for your answer
I reinstalled the .tar of ISE 14.6
But I get the same error
Dag
Hi @dag1,
Did you try setting the LD_PRELOAD variable?
Rajesh
I added the line:
export LD_PRELOAD=/more-space/Xilinx/14.6/ISE_DS/ISE/lib/lin64/libXst_Core.so
It solved the problem.
However, when I open a terminal window now I get a new error message:
/bin/sh: error while loading shared libraries: libPortability.so: cannot open shared object file: No such file or directory
It seems that setting the LD_PRELOAD to the .so caused this error
Any advice ?
Dag
Refer this AR http://www.xilinx.com/support/answers/22497.html for new issue.
Yash
I followed the instruction
putting in the PATH variable
(instead of nt folder using the following folder)
/Xilinx/14.6/ISE_DS/common/lib/lin64
which contains the file  libPortability.so
However, I still get the error
when I open a new terminal
